I changed the tranny fluid and filter. Only drained about 2.5qts out of the pan. Replaced approx the same (the first time). First run and shifting was sluggish with the truck jerking into gear. Drove a mile or two and it cleared up. Parked it and the next day now I have no forward gears. Reverse only.
After the first "test run" I pulled codes P0761 and P2714 and P2757. I then drained the pan a second time and pulled all the shift solenoids and bench tested with 12V. All actuated properly. Anyone have suggestions for next troubleshooting steps?
Discussion Starter #2
More info. Nothing in the pan that suggests catastrophic failure. Only some fine silt. Verified fluid level at correct temp.
