1 - 8 of 8 Posts
Hey all, I had the typical "one click" when I tried to start the truck, so I went and got starter contacts for it and replaced them. I was kind of suspect that it wasn't the contacts, because when I took it apart, the contacts still had a good amount of beef left on them, and wasn't thin. I replaced them anyways, but now I still have that intermittent "one click no start problem. I swapped the starter relay with the one in my friends Tundra, and it fired up, but when I turned off the truck and tried to restart it again, I got the same "one click no start". Any Ideas what else it could be? I noticed the battery was weak, but it could have been from trying to start the truck so much. I'm thinking maybe the solenoid?
hi, it might be the battery going bad.
or the cables( POS./NEG.)either loose, degrading, or terminals.
since you changed a few things.
i'd hate for it to be the flywheel.
meaning 1 or 2 teeth are worn or broke.
good luck,
gorilla
Mech. Engr. / Mechanic
It is possible that it could be the starter itself. Your truck is 10 years old! I'd check the battery, cables and connections first. It's common for a starter to do the 1 click bit if it's not getting enough juice. It wouldn't be flywheel teeth, or the starter would spin without turning the engine over.
Replaced the starter with a reman, and replaced the battery. Good as new now. When I took out the old starter I noticed it has an internal rattle. That battery was also super weak and I put a new one of those in also.
Glad you got it worked out.
Toyota engineers should be shot for the starter placement...Just my .02. Nice job figuring it out. Too bad it came to that though. What a PIA!
1 - 8 of 8 Posts
