Hi all, new to the forum and in need of help replacing bank 1 sensor 2 on my 06 v8 . Po 138 high voltage is active code getting set about every 50 miles. This sensor screws into the catalitic converter through the heat shield covering the converter. I have applied penetrating spray and let sit a few days. Tryed loosen the sensor using slotted socket after warming engine to operating temp. Used medium force with no luck.I know that beneath the heat shield there is a mounting plate the sensor screws into and the plate attaches to the converter. I have been trying to remove the sensor without taking off the plate or heat shield. This is not my only transportaion, so I am in no rush. Giving the penetrant more time to loosen up and not srip or break the sensor. Interested to know any tips or advice
