New writer in the forums but long time reader.
I have a 2004 toyota tundra limited 4dr rwd, has 78k miles on it perfect maintenance but recently came across a huge problem.
My check engine light cruise control, abs, and srs airbag lights all came on, hooked up my OBDII scanner to it and it failed to communicate, I replaced the obd/cig lighter fuze and check all other fuses, including the abs, and ecu fuzes. I am pretty stumped I am about to check the pcm that it is seated correctly. Any other suggestions or hints?
