1 - 7 of 7 Posts
Im having an issue with my offset. the guy i bought them from said they are a +10mm offset but IMO i think they are a -10mm offset.
Can you please post pictures of your offsets and let me know what the offset is.
Here is a pic of my offset. If you can tell what mine is let me know cause i have no f-ing clue. im so confused cause i think its causing the problem im having.
thanks in advance
from rear tire driver side
from behind front tire driver side
here is a friend of mines (ImDone) +10mm offset.
From all the info I gathered a 10+ offset will stick out past the fender. What's the width of your rims compared to your friends? Tire size will play a role in the overall look as well.
9" wide wheels with a +10 offset would stick out about as far as your show. -10 would be almost another inch further out.
that is a -12 inch offset. any positive (+) offset isn't going to stick out that far. I'm running a -12 offset, and it is identical width from the fender
Those wheels look like they come in a +10, 0, -12 & -25 offsets, and in a 9 & 10" width. Understanding offsets and backspace can be very tricky. It depends on which width rim you have. Those tires probably stick out more past the rims, than the rims do from the fenders. What problems are you having?
1 - 7 of 7 Posts
