My 2005 Sequoia received Mobil 1 Synthetic 5w20 at the last oil change. I drive mostly in hotter climates. Any problem with this choice? Also, the rear window is non-op and the handbook does not seem to give a fuse location for this window. Not a big deal since I seldom use it, but I like things to work. Any suggestions?
If you run Mobil1, make sure you get the extended performance version. It's only a few bucks more...but rates higher.
