So I did my 2nd oil change today. When I was removing the oil filter drain bolt, the oil filter cap just came off, instead of the drain bolt. I tried unbolting the filter drain bolt after, but it won't budge at all. So I couldn't switch the little O-ring in there also. Anything I should be worried about, except a messier oil change? I was able to remove that drain bolt on my first oil change, don't know why I can't do it now.
