Forum Admin
5w-30, engine oil
75w-90, front differential, transfer case, rear differential oil (w/ LSD)
75w-140, rear differential oil (w/o LSD)
DOT3, brake fluid
ATF, power steering fluid
Toyota WS, transmission fluid
Moly-Lithium NGL2, driveshaft grease (chassis)
There's more, but that'll get you started.
Super Moderator
5w-30, engine oil
DOT3, brake fluid
Great info, but note that it pertains to a 2005-2006 model year 4X4 Tundra V8. The OP didn't specify (as far as I could see...) his vehicle.
Forum Admin
can you please specifiy which parts are different? :ts:
Super Moderator
Sure! For example, my 2002 calls for an SAE 90 hypoid for the rear differential lube, not a 140W, and the specced ATF is Dexron II or III or equivalent. The Toyota WS ATF is for the 2005-on transmissions. :tu:
