Just bought a 2005 Tundra/double cab with 4.7 engine. When I went to check the oil, noted it was over filled by about 1/2 inch.??
So, was that done by the dealer to get the oil pressure gage to work?? Note the oil pressure gage comes up at start to about 9 oclock postion and after warm up stays at 8 oclock position, right on the line. Is that normal position? 155000 miles. Should I immediately drain some oil to get the level back to the full mark. Just two dots on the stick, assume the top one to be full and the bottom to add, like other sticks.
