Hi, I am tearing down my engine and need some help, anybody know the best place to get it?
is there an online service manual available, I have a Chiltons paper copy.
my immediate problem is that I have taken out the passenger side engine mount to drop the engine down to remove the timing cover, but the engine only drops so far, I can't remove the power steering unit although I was able to remove one bolt and loosen the other but couldn't remove it because it hits the fender. Is there a trick to lowering the engine? or raising? I see the Torx screw will be difficult to get to also.
Any ideas on removing crank bolt would be appreciated too.
1AZ engine (2.0L)
