P0125 and p0155 codes
59 views 2 replies 3 participants last post by  cheapskate
#1 ·
I have a P0155 and a P0125 check engine light code that I can’t seem to figure out. I replaced the 02 sensor but I keep getting the same code. What else could it be ?
#3 ·
You said you replaced the 02 sensor. As in singular? Not an expert but there's a recurring theme I have seen on here multiple times over.
1-02 sensors are a wear item. They're usually good for about 100 k's. If you replace one, replace them all around that time.
2-Toyota's dont always work well with Bosch so make sure you buy Denso only.
3- Watch for knock offs. Apparently there's a lot of counterfeit stuff out there now.
Read posts 13 and 15 here.
And if you do figure it out, dont be one of those guys that never comes back and leaves another dead end thread. Be one of the good guys and come back with how you fixed it.
  • Like
Reactions: Gray Limited
