P0430 up/down stream ?
7K views 4 replies 3 participants last post by  yhangout
#1 ·
I have the 2007 SR5 4WD
I just had the P0430 came up, then I did the sensor extension on the up stream O2 sensor, It seems didn't work. every time I reset it, the code came back again and again after around 40 miles
so, Is the "P0430 code bank 2" for the passenger side up stream or for the down stream right next to the cat?
if I need to replace the O2 sensor, which one is good besides the Toyota OEM
please advice
#4 ·
P0430 occurs when the bank 2 (Passenger Side) downstream (PAST the catalytic converter) O2 sensor is detecting that the converter is not working as efficiently as the specifications say it should.
There are a few common causes. Among them are exhaust leaks, failing O2 sensor(s), engine misfires, leaking/faulty fuel injector(s), leaking head gaskets, internal engine damage or a failing catalytic converter.
The use of spark plug non-foulers or "spacers" is intended to artificially create a difference in readings between the upstream and downstream O2 sensors, thus fooling the ECM into thinking there is a difference in sensor readings, thus showing (false) cat efficiency. To do this, one would use the spacer on the downstream O2 sensor. I would advise against this, however, as you are ignoring another, potentially greater issue.
Catalytic converters are not a wear item. Other external conditions can cause them issues, like excess oil consumption which could coat the interior platinum-palladium and prevent it from doing its job. Rust or rot holes could develop causing leaks or they can be physically damaged by impact.
But otherwise, they should last a VERY long time. Virtually forever.
I would start to look deeper into other potential root causes.
Remove the non-fouler and start looking for exhaust leaks and misfires first. Start checking spark plugs and ignition coils and then finally testing O2 sensors, in that order.
Once you've ruled out all other potential causes, THEN start looking into replacing the cat. It's the least likely culprit in my opinion and is also the most expensive.
Good luck and let us know what you find.
