Chances are if you are reading this, it is because you did a search because your Tundra or Sequoia has thrown these codes and gone into limp home mode.
Happened on my wife's 06 Sequoia. I have an '06 Tundra with the same miles on it.
"Secondary Air Injection System Switching Valve Stuck Open Bank 1"
There is a 30 page thread on bypassing this system. Evidently, this is a common problem, resulting in secret extended warranties on some vehicles. So common, in fact, that at least two guys have engineered a work-around system to eliminate the codes, turn off the system, and allow the vehicle to be used for "off road use only."
The whole system only runs for about 30 seconds upon engine startup in some conditions, pumping air into the exhaust manifold to help the catalytic converter to heat up quickly.
This is reportedly a $3000 repair
But let me tell you, if you can do a timing belt, this job is easier and you might get by with under $200 in parts, depending on the mode of failure.
I pulled off the intake manifold and removed the air switching valve. It had a very slight leak in it, caused by a bit of debris. I disassembled the valve.The debris was just a bit of oily, fluffy dirt-looking stuff. I decided to
continue down the diagnostic and repair process outlined in the service manual. The pump tested fine. I removed air switching valve #2, Bank 1 (driver's side) and it was obviously stuck open. I disassembled it and found two small pieces of white plastic keeping it from closing. Those plastic pieces are the vanes of the air pump. I removed them and reassembled the valve and it was then working correctly. So it needs a new air pump. You can get a new air pump off eBay for about $125. A $30 FelPro intake gasket set from a local auto parts store.
Attached are pictures of the air switching valve with debris, air switching valve #2, the valve location (behind the starter) behind the manifold, the debris IN the valve upon disassembly, and a close-up of the debris.
It's good to figure this stuff out and do the work myself rather than pay thousands to a dealer!
I will install the bypass kits on the Sequoia, and maybe even my Tundra, to prevent this from happening again, "for off road use only".
Joe
Joe
