My new Recon CCL's come in on Tuesday and I want to put them on ASAP. I know the measuring is going to take a while so I stripped the interior and am trying to find the pickup for the lights to save me some time. I got the wiring cheat sheet from the12volt.com and it says the parking lights are green (+) below the fuse box.
I took my dads voltmeter and started testing wires. I found one in a black plug behind the kick panel that went to 8.8v when I turned the lights on. I know it should read 12v but the battery on the meter was going and I think this is why I got a low reading.
One concern I have is that this wire is a smaller gauge than I think it whould be. To confirm this was the parking lights I unplugged the harness and the lights still went on when I turned the knob. If this is the wire shouldn't the lights have stayed off after I unplugged it..?
I have a pic of the plug/wire that I tested and want to make sure this is infact the right wire. Can anyone help me confirm this..?
Thanks.
How are your going to wire the lights? Are you looking for the marker light wire to use it as the power for your cab lights or as a trigger for the relay to them? If it's just a trigger, then wire size is less important than if you are going to actually pull power from them.....
Good luck !!!!
I don't need to use a relay because the parking light trigger has a (+) polarity. I want to tap right into the parking light wire to feed the CCL's only when the parking lights are on.
if they are LEDs u certainly dnt need a relay but if they arent depending on what i tie into you might want them. any chance that wire is one of the dash light parking light wires? same circuit but different function?
