All stages come as a complete kit including disc, pressure plate,
throwout bearing, pilot bearing (when applicable), and alignment tool.
Assembled in the USA
FX100: Street Performance Clutch Kit
The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation.
FX100 Clutch Kit
4Runner - 89~96 - 2.4L 2WD 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
4Runner - 93~96 - 2.4L 4WD 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
4Runner - 88~96 - 3.0L Eng 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
4Runner - 96~02 - 3.4L Eng 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
FJ Cruiser - 07~10 - 4.0L 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
RAV4 - 04~06 - 2.4L Eng 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tacoma - 95~04 - 2.4L 2WD 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tacoma - 01~04 - 2.4L 4WD 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tacoma - 95~04 - 2.7L 2WD/4WD 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tacoma - 05~10 - 2.7L 2WD/4WD 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tacoma - 95~03 - 3.4L 2WD/4WD 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tacoma - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tundra - 00~04 - 3.4L 2WD/4WD 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Tundra - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
FX200: Street Longevity Performance Clutch Kit
The FX200 System uses the Power Plus I Pressure Plate and a Steel Backed Kevlar disc. This clutch is designed for the street enthusiast or weekend racer. The FX200 offers similar torque holding capacity to the FX100, however, its life expectancy is increased 2-3 times with the Kevlar disc. Our Kevlar friction material is non-abrasive and doesn't score the mating surfaces. It features only slightly increased pedal pressure, significantly longer life than stock, and normal clutch feel during engagement and disengagement for the smoothest operation of any stage we offer.
FX200 Clutch Kit
RAV4 - 04~06 - 2.4L Eng 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
FX300: Street/Race Performance Clutch Kit
The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement.
FX300 Clutch Kit
4Runner - 89~96 - 2.4L 2WD 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
4Runner - 93~96 - 2.4L 4WD 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
4Runner - 88~96 - 3.0L Eng 6Cyl - HD Plate - Dampened hub segmented Kevlar disc
4Runner - 96~02 - 3.4L Eng 6Cyl - HD Plate - Dampened hub segmented Kevlar disc
FJ Cruiser - 07~10 - 4.0L 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
RAV4 - 04~06 - 2.4L Eng 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tacoma - 95~04 - 2.4L 2WD 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tacoma - 01~04 - 2.4L 4WD 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tacoma - 95~04 - 2.7L 2WD/4WD 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tacoma - 05~10 - 2.7L 2WD/4WD 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tacoma - 95~03 - 3.4L 2WD/4WD 6Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tacoma - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tundra - 00~04 - 3.4L 2WD/4WD 6Cyl - HD Plate - Dampened hub segmented Kevlar disc
Tundra - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Dampened hub segmented Kevlar disc
FX400: Race Performance Clutch Kit
The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation.
Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material.
FX400 Clutch Kit
4Runner - 89~96 - 2.4L 2WD 4Cyl - HD Plate - Four-puck ceramic Dampened disc
4Runner - 89~96 - 2.4L 2WD 4Cyl - HD Plate - Six-puck Rigid ceramic disc
4Runner - 93~96 - 2.4L 4WD 4Cyl - HD Plate - Four-puck ceramic Dampened disc
4Runner - 93~96 - 2.4L 4WD 4Cyl - HD Plate - Six-puck Rigid ceramic disc
4Runner - 88~96 - 3.0L Eng 6Cyl - HD Plate - Four-puck ceramic Dampened disc
4Runner - 88~96 - 3.0L Eng 6Cyl - HD Plate - Six-puck Rigid ceramic disc
4Runner - 96~02 - 3.4L Eng 6Cyl - HD Plate - Four-puck ceramic Dampened disc
4Runner - 96~02 - 3.4L Eng 6Cyl - HD Plate - Six-puck Rigid ceramic disc
FJ Cruiser - 07~10 - 4.0L 4Cyl - HD Plate - Four-puck ceramic Dampened disc
FJ Cruiser - 07~10 - 4.0L 4Cyl - HD Plate - Six-puck Rigid ceramic disc
FJ Cruiser - 07~10 - 4.0L 4Cyl - HD Plate - Lined ceramic Dampened disc
RAV4 - 04~06 - 2.4L Eng 4Cyl - HD Plate - Four-puck ceramic Dampened disc
RAV4 - 04~06 - 2.4L Eng 4Cyl - HD Plate - Six-puck Rigid ceramic disc
Tacoma - 95~04 - 2.4L 2WD 4Cyl - HD Plate - Four-puck ceramic Dampened disc
Tacoma - 95~04 - 2.4L 2WD 4Cyl - HD Plate - Six-puck Rigid ceramic disc
Tacoma - 01~04 - 2.4L 4WD 4Cyl - HD Plate - Four-puck ceramic Dampened disc
Tacoma - 01~04 - 2.4L 4WD 4Cyl - HD Plate - Six-puck Rigid ceramic disc
Tacoma - 95~04 - 2.7L 2WD/4WD 4Cyl - HD Plate - Four-puck ceramic Dampened disc
Tacoma - 95~04 - 2.7L 2WD/4WD 4Cyl - HD Plate - Six-puck Rigid ceramic disc
Tacoma - 05~10 - 2.7L 2WD/4WD 4Cyl - HD Plate - Four-puck ceramic Dampened disc
Tacoma - 05~10 - 2.7L 2WD/4WD 4Cyl - HD Plate - Six-puck Rigid ceramic disc
Tacoma - 95~03 - 3.4L 2WD/4WD 6Cyl - HD Plate - Four-puck ceramic Dampened disc
Tacoma - 95~03 - 3.4L 2WD/4WD 6Cyl - HD Plate - Six-puck Rigid ceramic disc
Tacoma - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Four-puck ceramic Dampened disc
Tacoma - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Six-puck Rigid ceramic disc
Tacoma - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Lined ceramic Dampened disc
Tundra - 00~04 - 3.4L 2WD/4WD 6Cyl - HD Plate - Four-puck ceramic Dampened disc
Tundra - 00~04 - 3.4L 2WD/4WD 6Cyl - HD Plate - Six-puck Rigid ceramic disc
Tundra - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Four-puck ceramic Dampened disc
Tundra - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Six-puck Rigid ceramic disc
Tundra - 05~08 - 4.0L 2WD/4WD 6Cyl - HD Plate - Lined ceramic Dampened disc
FX500: Race Only Clutch Kit
The versatile FX500 System uses either the Power Plus I or Power Plus II Pressure Plate along with a solid center 4 or 6 wing (paddle) Ceramic Button disc. It is designed for maximum holding capacity with no compromises.
***Warning: The FX500 is a Solid Hub (rigid) disc that engages and disengages instantly. This is a Race Only clutch.
FX500 Clutch Kit
RAV4 - 04~06 - 2.4L Eng 4Cyl - HD Plate - Four-puck Rigid ceramic disc
GO TO NOPI/CLUTCH MASTERS Catalog for model specific web prices and details
Contact the salesmen below or PM me for our best deal on CLUTCH MASTERS Clutch & Flywheel kits
