saw it. to bad its not accurate since they used different trucks, same model but who cares. every car/truck will get diff gas mileage. i am sure the mileage on the trucks was not the same, oil change/viscosity not the same, tire preesure not the same, alignment not the same, tire and tire tread depth not the same, maybe one had syn diff dluid, and the other didnt, etc, etc.
if they used the same truck twice, i would be more apt to beleive the results. very surprised myth busters hung themselves on this one, its just not accurate.
Except that they redid the test in a "Myths Revisited" episode and here are the results useing only 1 truck.
It's just too bad they never tested it with a canopy.
The Myth: Tail Gate Up or Down.
In this continuation of the original myth, the guys test whether it is more efficient to:
1) take the tailgate off
2) replace it with a mesh tailgate
3) cover the back of the pickup with a tonneau cover
4) keep the tailgate up
5) put the tailgate down
The Action/ Results: They hook up a flow meter to Jamie's pick-up to test how much fuel is being used in each test. They also decide to use a straight, 5-mile stretch of highway for each test.
Test 1 & 2: This time they just try to re-confirm their original tests for tailgate up or down. Tail gate down uses 5.2 gallons per hour at 55mph and 1.2 gallons per hour at 25mph. Next they test tail gate down and it uses 5.0 gallons per hour at 55mph. At 25mph they don’t say the reading but it confirms their original results.
Test 3: This time they test the fuel efficiency of the tonneau cover. It clocks in at 1.2 gallons per hour at 25 mph and 5.0 gallons per hour at 55mph.
Test 4: Then they test the efficiency of the tailgate mesh. They didn't reveal the results but Adam said the mesh was an improvement of 5% over all the other methods.
Test 5: This time they test the efficiency of no tailgate at all. They didn't reveal the results for this but said it was roughly the same as the others except mesh.
The mesh won in the end at an improvement of almost 5% over the other methods.
Original Myth – Re-Confirmed
The myth that the tailgate mesh improves your fuel efficiency; Confirmed
Taking the tailgate off: Busted
