Hey 07Sport, because of your thread I just ordered the complete set. My question to you is, are there any tricks to making this an easy quick install? Bye the way, it looks awesome and I love the Blue Streak. For some reason my dealer couldn't find it in Calif. so I went with Nautical Blue.
Thanks alot. I really like the Nautical Blue also, but wanted the sport package. The upper grille and main grille are quick and easy. Upper grille you just pop off the stock one, drill 4 holes and the new one goes on w/ some plastic rivets. The main grille you just position in place, stick the screws through the mounting holes and secure them w/ the wing/hinged nuts on the back of the grille.
The bumper is a pain in the ***. Hopefully youll get all the brackets. They left out six "flat" brackets in mine. Their design has you basicly sandwiching the L bracket and the flat bracket around the bottom plastic lip in the gray plastic piece on the bumper. Then mounting the actual grille pieces to the upper turn of the L bracket. I dont see how it would work very well personally, but maybe you can get it. I simply took the L brackets and drilled another hole farther in on them. I then removed the plastic piece off the bumper (easy other than 2 bolts that were tough to get off. I simply left them out. Its held in w/
15 bolts). Then marked/drilled the corresponding hole in the actual plastic and bolted them directly to the gray plastic piece. So now instead of being clamped on, they are physically bolted through the gray plastic bumper piece.
Anyway, glad you like it and hopefully youll have an easier time w/ the bumper piece than I did. Overall though I feel it was worth the time/effort as I really like the final look. Good luck.
