For those of you that have upgraded your speaker wiring to your door speakers, can you post up your photos of how you pulled it off? Did you modify the factory harness and connector or run a second harness and shielding for the new wiring? Post your photos!
For the fronts I just ran thru the factory boot since there was plenty of room.
For the rears I drilled out two unused holes in the factory molex with my Dremel (lower right).
Once they were drilled out there was enough room to run 14awg wire thru.
Tied it all off and that was it. This is for an 07 though, I saw that yours is gen.1, not sure if you'll have the same options that I did, but hope that helps anyway.
