61 - 64 of 64 Posts
Does anyone have any input on sequoia shocks in general is this a really common problem? I just test drove a platinum with 100K miles on it yesterday and I’m 99% sold but have to do a little research first. Any input on common problems would be great. I’m converting over from a 1st gen Pilot and have done all the work it needed except for a timing belt change (all about the sequoia chain). Used to have a 22r truck (245k miles) way back and coming back to Toyota. The sequoia test drive was awesome!
Mine has 116k now, everything works as intended, stiffness adjustment has no issues, airbags the same. If you plug the VIN to the Welcome to Toyota Owners you can check any maintenance records from the dealerships. If you plan to tow or rock-crawl I'd flush the transmission at that mileage. If nothing leaks or there isn't any wreck history you should be fine.
61 - 64 of 64 Posts
