1 - 8 of 8 Posts
About 3 days ago I decided to clean my throttle body. After taking the intake off I was surprised to see how much dirt/gunk had built up inside with only 17000 miles. I took a micro fiber towel and wiped it down with some carb cleaner. I sprayed cleaner directly to the towel, not to the throttle body.
I should have taken a picture of the towel afterwards it was hideous!
So far I have noticed a reduced "clunk" when downshifting or upshifting and normal driving. Everything seems much smoother operating.
Possible diagnosis for the clunk is that the throttle body is sticking, therefore when accelerating or decelerating a slight thud may be felt. Just my observations, this may or may not work for those with clunking trannys but its worth a shot. If anything you'll have a cleaner TB afterwards :p
Maybe you knocked one of the vacuum lines loose which raised your idle speed up enough to keep your driveshaft preloaded. :lol:
Nice try but the two are totally unrelated bud.
Yep I agree this is unrelated. However, there have been a lot of threads about this subject recently and I guess I don't really get this much. I have probably only had this happen a couple of times in three years. I come to a complete stop at stop signs, maybe that is why I'm not under the right conditions to experience this problem...
Nah, it happens at complet stops, like 2-3 seconds after the wheels have stopped completely. Feels like you got tapped in the back by a small car at 1-2 mph.
I cleaned my floor mats the other day and gained 3mpg!
Try it!!!!! Your truck will run better.......
im not surprised, K&n filters suk.... they breath more air cause they dont clean it as well.. the maf sensors and tbody's get coated with dirt with any k&n or cold air style kits.. they sound cool,, make a tiny bit more hp but dont clean very well... and thats what a air cleaner is for,, cleaning the air before it goes into the engine... lol
1 - 8 of 8 Posts
