Hi All:
This is a 2002 Camry LE 4 cl. with 40k miles on it. Yesterday onwards the driver's power seat has stopped moving forward-backword horizontally. It can still tilt and go up/down. I can hear a click when I push the button to move it horizontally but there is no movements. What could be the problem? Any obvious thing that I can chceck? Tracks look clear but I havent looked at it closely. Could it be just the weak battery? Is there any bypass for power stuff to convert it into manual mode? Thanks in advance for yout time!
Retired Contributor
Hi All:
You need a test light.
Operate the switch and if there is power in the fwd/bkwd wire at the motor, then the motor is bad.
If there is no power at the motor while operating the switch, then the switch is bad.
No , there is no by-pass or manual mode.
Make sure the vehicle battery is 100%
