Ok i need some suggestions.
I have the speedway blue color on my truck and thought it would be fun to run 2 strings of blue led lights under the lip of the top of the bed of the truck and perhaps a small string of led blue lights in the fuax hood scoop.
How to power them is where i am a novice as i have never modded any vehicle i have owned.
1st things first...i would check local laws...most have issues with either forward facing red/blue lights, or visible bulbs from red/blue lights for obvious reasons.
Secondly, your going to need to run wire to your battery terminal for power, most LEDs should be fine on a 12v power supply, just make sure to connect up the grounds and power and you should be good to go.
im sure someone will know better than I the specifics of the wiring...but that might be a good start.
Cabelas sells strip lights with the wiring and how to.They were in one of there catalogs I just got the other day. You should be able to see them on line, Mike
