I have a 2002 Tundra SR5 and the other day I rolled my windows down and the passenger side would not roll back up. Driver side works perfectly fine. I have tried a new switch and motor both. So far neither have worked just plugging them in and testing. I know it can’t be a fuse but I’m wondering if this is a wiring issue, BCM, or the driver’s side switch panel. I’m already about $60 deep in this with a window that doesn’t work and I still don’t know what to do. Any advice would be helpful.
2.5 years late but check for continuity on the wires going from the power window master switch to the right hand drive motor. These are pin 3 and 4 on the POWER WINDOW MASTER SW connector to pin 2 and 1 of the POWER WINDOW MOTOR FRONT LH connector.
