Hey everyone. I'm planning on getting a 6" lift kit on my 08 Limited Crewmax 4x4 Salsa Red. I was looking at getting the pro comp stage 1 lift kit becuase of the good price but wanted to know the main differences between the stage 1 and 2. Also how do the rides compare, and does the truck end up being level after either are put on? I tried contacting pro comp but no luck. Thanks for all your help.
Stage 1 uses spacers to achieve the lift up front. Stage 2 uses new coilovers. Stage 2 is much better if you can afford the extra $800.
So what's the difference between the spacers and the coilovers up front? Are the spacers bad? Is putting in a spacer similar to a body lift?
If you want to use it off road, get the stage II. Here is what happened when I did with the stage I.
