My '05 Tundra is showing problem codes P0175 and P0172. I'm thinking I need to clean or replace my Mass Air Flow sensor. I just turned 100K miles, do you guys think I should try to clean this one or replace it? Also, gonna change out my plugs. Give me some opinions on which are the best. Thanks.
I'd clean the MAF sensor first, rather than replacing it, and see if that corrects the problem. There's no need to start throwing parts at the truck. We'll help you figure it out. As far as the spark plugs go, use an OE equivalent Denso or NGK.
Moderator
