I've posted quite a few times the last month about a persistent problem that seems to be worsening. I feel bad because I feel like I always have a question/problem, but due to limited experience, have very little to offer in terms of solutions. So, it is with a great deal of appreciation that I post yet again about the continuation of this problem.
Engine has been stumbling off and on for a month. It's completely random. It may do today then wait three days and do it again. Each time, no check engine light.
I cleaned the throttle body and also did a seafoam intake manifold treatment.
Well finally, last Monday it tripped the light. It stored a 0303 and 0305...cylinder misfires in 3 and 5. I took it to a well known shop, not the dealer, and they concluded it was the coil packs on cylinders 3 & 5. He changed them and put new plugs on all 8.... Autolite Double Platinum. YUCK YUCK YUCK I Know. Those plugs lasted all of about 18 miles in my truck before the engine started stumbling again and sending check engine lights. I replaced them with the standard Toyota Denso plugs.
I installed the Densos but had some confusion about the gap. The dealer said they were pre gapped and had little protective caps on the electrodes. Well, the Denso site said to gap at .035. The Haynes manual said to gap at .031. The dealer said they were pre gapped. I checked them. They were gapped at .030. So I left them alone and installed them.
I also happened to check the Autolites that were in there. They were gapped at .045! So I figured that was these platinum plugs and huge gap that had the engine acting up and stumbling after getting it back from the shop.
I cranked it up and she ran great. No stumbling no hesitation. A completely different scene then from an hour ago. Well, since my original problem was intermittent, I held off on celebrating.
Good thing, we're right back to square one. Engine stumbles so badly it won't stay running. I was letting it idle and went back outside to check on it to find it dead. It wouldn't start. It cranked but didn't start.
SO I broke down and bought a OBDII reader. I just pulled similar codes as the original. This time it's 0300, 0301, 0303, 0304, 0305, and 0308.
After a few tries it finally started but still idles like hell. Giving it a little gas revs the engine, but poorly, and there is a noticeable rattle under truck...at about mid-way of the length of the truck.
Wonder if it's a cat issue. Please let me know what you think.
