Hello i have a 2003 toyota tundra about 6 months ago it started to hesitate when i would acclerate from a stop then it would go away as soon as i got going. I bought a can of fuel injector cleaner and ran it through (BG44K) and the problem went away for 6 monthes now it is back and seems to be worse even having trouble idling after starting. It goes away after pushing on the gas a couple times i think its the injector but not sure how to test wich one it is please help it is driving me crazy. p.s. i have replaced the filter and plugs with no change thanks for your time.
Time to clean your throttle body and maf. Do a search there is plenty of info. Mine was doing the same thing and it would almost die going from neutral to drive.
replace PCV valve if you haven't change it yet. This $12 valve will make your vehicle runs better & give you better MPG.
