Very nice unit. Make sure you buy the wire harness with it. Installs in less than 5 minutes, just plug in the connector and away you go.
Where did you mount yours? I'm going to move mine as it hits my knee. I knew I shouldn't have put it there but like a dumb @ss I did it anyway.Very nice unit. Make sure you buy the wire harness with it. Installs in less than 5 minutes, just plug in the connector and away you go.
How much did the harness cost?, did you get this from your toyota dealer?Very nice unit. Make sure you buy the wire harness with it. Installs in less than 5 minutes, just plug in the connector and away you go.
Like usual, the person at the dealer is uninformed. That is why I use the Internet to research just about everything.When I looked at the Chevy Silverado, I asked the dealer about a quick connect feature for the brake controller and he knew nothing about. He said I would have to splice in the wiring myself:td:
Who sells the harness??The harness part number is 3040
Can you verify which one it is? I think its the plain 3040?I bought the harness at rvwholesalers.com. The Tundra comes with a connector already installed. Just buy the wire harness to connect to the brake controller and plug and play. No wiring, soldering or crimping needed.![]()
My pleasure!Thanks mln...got one on order.
thanks mln,3040 is correct. I have that installed on my 07.
