I have a small tear in the driver side power steering gear boot where it connects to the tie rod. The advice I am getting from a local repair shop and the dealer is that the presence of the fluid indicates a bad steering rack and replacing it is going to run $800 - $900. The vehicle is a 2002 Sequoia 4x4 with 118K. Does this seem like the right advice? I am starting to hear a whine when I turn the wheel but, the ps fluid level is still good. The leak is very small. I am wondering how critical getting this handled is. I do have a pretty major trip coming up, don't want to risk having the steering freeze up. Any advice wold be greatly appreciated.
You need a new steering rack. Buy a part online and help someone (or Pepboys) that you trust to install for you. The dealer charge too much.
Hmm, not sure on the repair or if anything can be done for your existing steering rack. You may want to check some local wrecking / salvage yards I think I remember reading in another post that a used / salvaged unit could be had for about $100 or so??
Worth looking into.....keep us posted :tu:
Try a few searches as well, maybe someone else has a solution for this in a previous post...
Here's one...
