1 - 7 of 7 Posts
hello .. i have a tundra 09 5.7 supercharger .. does someone know how could i go boost ?? :D it is now 7 psi .. can i reach 10 or 11 ?? :ballchain:
I think the only way to get more boost is to have a larger crank pulley made. The one on the supercharger is already small and if you make it smaller you run a risk of belt slipping. no one really knows how much boost you can get out of these engines with out blowing it. So you run a risk upping the psi. i would say on stock internals you wouldn't want to go any higher then 9-10psi and with that you are probably really close to what the engine can take.
Edited
Fried 5.7 Motor? wow do you have any links for more info?
thanks
thanks
Wait a minute. I might be mistake but I thought it was your tundra that got fried? If I missed the boat on this one please straighten me out because I don't want to give any bad info to anybody.
Nope, just one rod that look like a snake (good thing that I could repair my self). But yes more boost, you'll need stronger bottom end on your engine :tu:
I cleared that post sorry about the mix up.
1 - 7 of 7 Posts
