1 - 12 of 12 Posts
hi today i seen 3 older tundra's. they cought my eye only due to the fact each 1 i saw was turning. i would swear that everyone of them ,there front end dived down & there rear end went up. instead of staying flat. i didn't think this was normal the 1st time, but after i saw the 3rd do the same thing. it made me wonder. 2 looked empty in the open bed, looked like nothing was in it. the other was a pool guy. all i saw was a shark outside the tailgate, in the middle, & a few items plastic pvc piping stuff in a milk crate. nothing i thought that was to heavy.
so i guess my question is this: is this normal. my 05 never did that. & now due to the front & rear HELLWIG anti sway bars, my tundra stays so flat around turns.
to me it almost looked dangerous, but i could be dead wrong. or i just seen 3 tundra's that needed shocks. i knew they were older because of the front bumper was steel, and the tail lights looked nothing like my double cab lights . they were small.
thankyou in advance for your comments,
just wondering... HUMMM...........:confused:
gorilla
dont think mine does that except when i stop then the nose dips a little, i do need to change my shocks i have almost 130,00 on them, just another thing to get on a long things to do list. i might be wrong you got me thinking now gorilla :confuseda:
The Tire Guy
I noticed mine did it before the coilovers. My mechanic was driving it after he changed the rack and pinion and when he pulled into our shop parking lot nose down a$$ up, it was weird I never noticed it when I was driving??
Probly have worn shocks, also the suspension is pretty soft stock. Mine does that, but I have no swaybars!!
hi, thankyou. i noticed this, while they were turning. other than that it looked fine, while they were driving. when in the turn the tundra did sort of a swisted nose dive. i never noticed that on my 05, even before i did the up-grade in sway bars. but it just looked like it was diving way to much. i wonder if you were taking a turn fast what would happen. these 3 tundra's, were not going fast. that is why it cought my eye.they were making left turn & i was behind them all. it seemed that there weight all went into that front fender/tire, pushing down hard.while the rear lifted up. it to me didn't seem safe. i thought what if they had to slam on the brakes. i would think & i could be wrong but the rear up since the front was down & twisted, and the rear was up. it would was slid out & around.
if i were you. i'd have a friend watch you make a turn. and see what the truck does.
yes, it might hve worn shocks, but thats easy to check. while standing still push up & down on each fender. & see if the travel continues to bounce a few times. instead of down & up, than stop's.
i only posted this thread to inform you. i belive it could lead to a safty issue.
if you were going faster than normal, & than traffic was stopped as you make that turn right in front of you.
what would happen to the front/back. it looked weird.
i hope all is o.k. & this is normal for these years.
and it is totally safe.
good luck, stay safe TS brother's!
regards,
gorilla
I think your observations are accurate, but are much more noticeable as the shocks get worn. Another thing you will notice when the shocks get really worn is a up and down sensation while you're turning. Another handling characteristic is noticeable understeer, even with new shocks.
To tell you the truth, I've never really paid attention to know whether is dives of not. Now you have me worried...
Discussion Starter · #9 ·
hi i'm sorry.
i didn't post this thread to make you all worried.
i posted it with good intentions.
if there is something wrong, or can be fixed, i would hope you would at the least try, & see if your tundra does this.
i assume you have been driving the tundra now for many years.
but i would, like i said, have a friend either look at it while you are turning or have a friend drive your tundra & make the turn to see what happens & what you see.
maybe it was just these 3 tundra's that really needed shocks so badly.
anything is possible.
good luck everyone, i hope it's just something normal.
if you see another tundra like your's ,watch them turn, you hopefully will see what i did.
than you will have a better idea of what i was looking at.
i know 1 thing for sure, when i put my rear hellwig it stiffened up the tundra,
than i also added the front hellwig, it make it even better. now aorund turns it stays so flat.
like i have been saying like a BMW or AUDI!
maybe that is all you would need.
i don't know what the problem is, maybe nothing is wrong.
but i wanted to let you all know.
better to be safe than sorry.
good luck to you all.
regards,
gorilla
gorilla
thx gorilla will have someone drive my truck and check it out. btw a trd swaybar is on my list so are a set of trd bilsteins red/blue, hopefully that will help out, and thank you once again for watching out for us
Discussion Starter · #11 ·
hi, your welcome.
this is what a botherhood should do for each other.
that is what i belive.
it's like when i ride my bikes, we always put out my finger's peace down, out to each other, it is just saying hello for a fellow rider.
i do it to all biker's. harley's, rice rockets ,etc.
i have both a cruiser & a rocket.
it's a brotherhood.
i always stop if a biker has broken down, just to see if he/she needs anything.
i truely hope 1 day we(TS) get the same way.
gorilla
hi today i seen 3 older tundra's. they cought my eye only due to the fact each 1 i saw was turning. i would swear that everyone of them ,there front end dived down & there rear end went up. instead of staying flat. i didn't think this was normal the 1st time, but after i saw the 3rd do the same thing. it made me wonder....
so i guess my question is this: is this normal...
to me it almost looked dangerous, but i could be dead wrong. or i just seen 3 tundra's that needed shocks. i knew they were older because of the front bumper was steel....:confused:
gorilla
Interesting observation. My 10 year old Tundra does not have that problem. But, I did help it along the way..all upgrades with less than 3k miles, and I like the difference in handling
. Front and rear sway bars
. New poly bushings front and rear
. New Red/Blue Bilsteins shocks front and rear
. TRD coil springs up front
I am sure you saw some older rides with more miles, as expected for most older trucks. I may not be a good example with only 23k miles right now, and suspension with only 3k.
1 - 12 of 12 Posts
