Super Moderator
What about fitting a 375/55/16 ( 32.4" tall / 15.4" wide ) DICK CEPEK Tire to my Tundra.
Dick Cepek Radial F-C II
Would a tire with a width of 15.4"s on a Dick Cepec Rim of 16X12 sized rim (required)Dick Cepek DC-1 with 4.53" b/s' ing and -50mm offset even fit? I haven't even seen someone go this big other than Stealth's truck with 14.50" wide tires.
I know the front wouldn't fit very well without tubbing, cutting the pinchweld, etc. and at least a 6 inch plus lift. And Body lift. What about running this for the rear tires and a set of 32.8" - 33.1" tall 12.5 wide in the front. The sizing differance in tire height front to rear shouldn't affect the drivetrain in 4 wheel drive , right?
Super Moderator
Discussion Starter · #2 ·
Okay I know some of you have 16x12 wide rims!!!!!!! Whats up?
Do the huge tires you have turn Well......, Lock To Lock?
With what B/S did you go on these massive sized Rims?
And What sized tires are you running in exact Width/Height on your 16x12" Rims
And what all Problems occured if any for those who have run this combo of tire/rim for the Tundra ? All help is useful to myself and others wanting to Run HUGE tires
