Removing radiator on a 2005 4.7l. There are two lines for the transmission going into the bottom of radiator. How do I remove them without dumping the contents on the ground (i.e. really don't want to have to refill the sealed transmission.
put a drain pan below it before disconnecting. only a small amount will drip out. make sure to check the level afterward and refill as necessary.
Supportive Supporter
I stuck a chunk of 3/8" (I think :dry3d:) fuel line between them.
Not much will leak out.
Thanks for the info. I realize it isn't a lot that came out, but I was surprised to find no way to keep it in when removing the radiator.
