This morning I was filling a low tire using an air pump which ran from the two Auxillary power outlets in my tundra. The Air charger (auxillary outlets) turned off, and at the same time the radio and clock stopped working.
I thought it had something to do with the fuses so i went to the car parts store and got new fuses. I changed the two power outlet fuses (15amps) and the radio fuse (20amps). The radio and clock and cigarette lighter (auxillary power outlets) still do not work.
Any DIY suggestions before bringing the truck in?
Thank you.
Thank you.
