Does anyone on here by chance know how to tell a Rancho Quicklift left strut from the right strut? My new Rancho Quicklifts do not have the part numbers on them and my wife thought it was a good day to burn trash. I had the boxes laying next to the corresponding strut. I know I ordered a specific part number for right and one for left, but I cannot find a difference. Help please.....and thanks!
A quick call to Rancho and problem solved. Yellow caution tags on the springs. Left has a 178 on bottom of label and right has a 179 on the bottom of the label. Now if I could just get the damn things in! I really don't want to pull the ball joint, but they won't fit even with the stab link off. Maybe I could loosen the knuckle??? Guess I will try again tomorrow.
So how do you like the Rancho quicklifts? How much lift did they give you?
I have them too and I would say between 3-3.5 inches. I had to put a 1.5 inch block in the rear to make it sit even if that gives you an idea. I like them a lot and they were an easy install since I did the ball joints at the same time so I just busted out the old ones. I know Remmy isn't fond of them, but to each his own. I haven't had a problem with them and I like being able to adjust the stiffness. Looks even better with a 3 inch body lift too. :D
