1 - 8 of 8 Posts
I just got a 3/1 readylift installed and there now seems to be rubbing, didnt change out the tires or wheels and it didnt rub before the lift, i think it might be rubbin on the skid plate. What could i do to fix this problem?
And how do you add photos?
Does in only rub when you turn the wheel all the way? There are 2 reasons usually for rubbing after a level kit. 1st one you mentioned already. 2nd one is a lot of peaple had metal rubbing sounds after install from the installer bending the brake dust back plate and it rubbing the rotor.
i took back to the shop and they trimmed the skid plate and took the flaps off in front of the tire, ill check it today, but it was at full lock when turnin
Discussion Starter #5
yes they did the alignment, all seems to be well after i took it back to them to trim the skid plate some
Discussion Starter #8
extreme offroad in katy, texas and it was $700 with the alignment, they do good work, they did the suspensin work on my last 05 ford wich was lifted 8"
1 - 8 of 8 Posts
