02 tundra differential leak after changing pinion seal three times. What I found was a leak in the carrier, rusted through was leaking oil and the seals I was changing were good.
I found it by taking the vent out and putting 4 pounds of pressure in the housing then spraying it with leak check where I suspect the leaks were.
