Hello
Would there be any problems stacking the wheelers 1.5" add a leaf and a 1" or 1/2" rear lift block together to get the lift look i'm going for.
My plan is to install the 2" sway a way at 2.5 inch lift up front and the wheeler 1.5" add a leaf with 5100's in the back. Ivan Stewart wheels and some brand of 285/75/16 tire
My problem is that the rear only sit's 5/8" higher than the front with the ARE lid and a few hundred pounds of load most of the time (carpenter). So if the lift numbers are correct then the rear will be 3/8" lower with load and level when unloaded i believe. I don't mind a slight rake when unloaded.
Just woundering if i can stack the add a leaf with the block, my guess is i can
Thanks, Dave
Thanks, Dave
