Drop the tail gate down and remove the two bolts holding the tail light assembly. You'll need to "pop" the tail light out. Give it a little nudge and they'll come right out.I need to replace the passenger side rear light housing but I can't detach the old one....Grrrr!! I've located the connection but I can't get it apart. Is there a trick or a special tool required to do this? Thanks!!
