Is there a factory location for rear tow hooks?
I'm considering getting the loop that goes into the hitch receiver.
I've done this for the longest time, it's the easiest way to go for a straight pull.Use your reciever hitch pin to slide into the loop of your tow strap inside of the receiver hitch.
-Mack
Would this work for a chain with a hook on the end, not a loop?I've done this for the longest time, it's the easiest way to go for a straight pull.
if you have the money, pick up the Warn slug with the shackle hanger, and a 3/4T Warn shackle (different from the shackles at Tractor Supply, same size but the Warn shackle has a thicker neck to the pin).
-Sean
I have straps with loops. I was just curious, cuz you never know.you are getting scarey talking of chain!
stay away if you can, buy quality straps with loops
Ok. Me first. lolThat depends how stuck you are, is it better to go out the front or out the way you went in? Every situation seems to be different.
In my towing years I had tow truck style j hooks and could snag the diiferential or leaf springs with a pair of them and carefully winch ya out.
Most trucks have what are called t slots for t hooks, they are used for tying down on transporters. they also work in a pinch, designed for pulling down and not back is the problem.
Hooking to your bumper is a recipe for disaster. you have to be cautious with brake lines abs controls etc.
IF there is room you can get a pair of tree savers and put one around each side of the pumpkin. Keep BOTH ends of each strap to the rear of the truck and join together with a high quality shackle.
If you stick the loop through the other and only bring one you would be guaranteed pinching something off.
JUST remember braklines etc. don't destroy things
Ok now the fun begins lets hear the pros and cons of this post. everyone has there own ideas and opinions thats what makes this a great site.
Uh...I had to ask because of what you recommended and the last line there which I bolded...That depends how stuck you are, is it better to go out the front or out the way you went in? Every situation seems to be different.
It would seem so.Uh...I had to ask because of what you recommended and the last line there which I bolded...
...Were you serious? (about strapping to springs, axles, etc.)
I had to do that with mine. Sucked down into the mud and it had to be pulled out at about a 45deg angle, otherwise the tow rig would've gotten stuck too. The frame was twisting and it was up on two wheels before the mud finally let go. I wouldn't recommend doing it with a modern vehicle... the frame problably wouldn't handle it.It would seem so.
I've seen people put a tow strap on a spring shackle, it pulled the vehicle sideways out of the hole, but it worked.
When my friend had his Jeep pulled by the bumper, he was being pulled by a farm tractor, and it just couldn't get him out.I had to do that with mine. Sucked down into the mud and it had to be pulled out at about a 45deg angle, otherwise the tow rig would've gotten stuck too. The frame was twisting and it was up on two wheels before the mud finally let go. I wouldn't recommend doing it with a modern vehicle... the frame problably wouldn't handle it.
