I have a 2005 Sequoia and the rear window won't roll down. I tried operating from the hatch, dash and key fob, as well as made sure the windows were unlocked. Anyone else have a problem with their rear window? Looks like a trip to the dealer.
Does your rear windshield wiper still work? Does your rear defogger still work??sarasota2k4 said:I have a 2005 Sequoia and the rear window won't roll down. I tried operating from the hatch, dash and key fob, as well as made sure the windows were unlocked. Anyone else have a problem with their rear window? Looks like a trip to the dealer.
Yeah, If that rear wiper is not in it's proper resting place the rear window won't work and your rear defogger won't work either witch is connected to your heats side views. I also read that if you disconnect the battery you have to push and hold the rear window button to make the window go down and hold it pushed for an extra 10 seconds. Then do the same going up, Push the up button and hold it for an extra ten seconds once the window is all the way up. This resets something with the rear window. I read about it somewhere on this site.Steve97TT said:I had that problem once after I had the battery disconnected. Actually, I noticed my rear wiper wasn't working and then I realized my rear window wasn't either. I got my multimeter out, checked a bunch of fuses, and jiggled the rear wiper.
To my surprise mine started working again in the middle of my troubleshooting (so I have no idea if I did something or if it was coincidence.) If you figure out what gets yours going please do share.
Steve
P.S. I suspected that the window wouldn't operate when it thought the rear wiper was not in its proper resting spot. If a fuse isn't blown I'd start at the rear wiper.
Rear Wiper/Washer - Check 7.5A ECU-B, 10A ECU-IG and 25A WSHsarasota2k4 said:I thought I could easily find the fuse, but I can't seem to find the fuse reference map. Anyone have an idea which fuse panel and fuse number controls the rear window and wiper?
sequioapower said:I would definitely stay away from the dealer doing it. You could actually try looking for a Camry power window motor or a newer 4runner motor. Good luck.
