I just wanted to post that I got the nerve up a couple weeks ago to attempt to repair the rear power sun shade on my 06 Limited. It took some time to get to the shade assembly itself but once I did, I removed two 10mmbolts and unpluged the wiring harness and the whole assembly came right out. I got it on the work bench and removed the control arm from the gear box and then the top cover of the gear box to expose the culprit of all my troubles with the shade. It was an 1 1/2" plastic drive gear with a small metal (1/4") gear attached to it. 4 or 5 teeth on the plastic gear was striped off. They don't sell parts for the sun shade and a new one is around $800.00 so needless to say, I won't have a sun shade any longer unless I can find somewhere to get the gear. Any ideas?
:dry3d:
