1 - 20 of 30 Posts
I just recently bought a 2006 Sequoia SR5 w 98k miles. Only issue which I didn't realize until I tried having a key made was the key that the small out of state dealer gave me was a valet key. When I took it to the Toyota dealership they said my only option was to replace the ECU & then get new keys made at a price of $576 plus tax! Any help would be greatly appreciated. Only key I have is a gray valet key. Just wondering if there are any for sure fixes to getting a reliable replacement key at a more reasonable price. Thank you all!
Dealer is wrong, go back an speak with someone that knows what they are talking about or go to a different dealer. All they need to make a key is VIN and proof of ownership. No key needed.
Ok. I tried another dealer. Now I have an extra key that will unlock the doors but it will not start my Sequoia. They attempted an immobilizer reset. Checked with Toyota in CA & said vehicle age exceeds parameters to allow reset process to work. I was told again ECU needs to be replaced if I want it repaired by Toyota. However Tech said there are places that will reset my suvs current ECU he just didn't know of any local places. Kinda of exhausting. Drove an hour to this place because they said they could fix it. However, I atleast have a way to get into the truck if I inadvertently lock valet key inside. Any help would still be greatly appreciated. Thank you.
Have you tried any of the online procedures to program the key? I did it with m 2006 Sequoia SR5 but I had a master key. I don't know if it works with a valet key. But it's worth a shot. I can't remember the exact one I used but here is an example of one:
How to Program a Toyota Sequoia Chip Key | It Still Runs
More google hits: https://www.google.com/search?q=toy...0.69i59j0l5.3133j0j4&sourceid=chrome&ie=UTF-8
It was kind of hard to get it right -- it took at least a couple of attempts before I got the whole pattern down and the new key worked. Amazon has replacement fobs (both a whole fob with innards and just a replacement outside for a worn fob).
Edit: actually, I didn't program a key. It was just the fobs. Sorry, it's been a while. So I haven't done it but it might work.
I have not. I never had a master key when I purchased this Sequoia a month ago. Just the valet key. Toyota dealership made me a new master key yesterday. However it's only function at the present time is unlocking the doors. It will not start the car. Only turn it over. I could try the above using the valet key & then inserting the newly cut master to try & program master. Not sure if that would work but most likely wouldn't do any harm either. Any thoughts?
Sorry but I don't buy what the dealer is saying. If they tell you that you must replace the ecu how will it learn your new key? Someone has to program a key and ecu to work together, so whats the difference between buying a new ecu and programming it or your current one? Maybe see if there is a lock smith in your area and ask them. It wont cost you a dime to call and ask.
What about where you purchased the Sequoia, did you buy from a dealer or was it a private sale? If it was a dealer I would be calling them and ask that they get hold of the previous owner and ask for the other keys. Its not uncommon for people to trade in a vehicle and just forget to hand in all the keys.
Discussion Starter · #9 ·
I've taken this Sequoia to two different Toyota dealerships. Same exact answer from both. Need a new ECU.
I bought the truck from a small used car dealer who had just purchased the vehicle from a local auction. Dealer is nearly 3 hrs away. Tomorrow I'm going to be calling local automotive locksmith's. To be continued...
Scary situation. My key is starting to deteriorate at the base and it will soon come apart. My wife's key works fine but that would leave us with a good key, a broken key, and a valet key. I vaguely recall that there is a maximum amount of keys that can be programmed before drastic measures (ECU?) have to be taken.
Did the dealer even attempt to make a dealer key ($200ish?) for you? I would ask them how they determined that it was "maxed out"... if averages are anything, the truck had the two original keys and the valet and that's it. If my foggy memory is anything, you may have two master/normal keys left on the tally to work with. Good luck. Keep us posted. I'm very suspicious of the ECU being called right off the bat.
Discussion Starter · #11 ·
12 keys is what I have read. Both Toyota dealerships claims that due to its age they can not program it. I'd take a picture of work order if I knew how to post it. They are both identical & expensive. Locksmith is coming to the house in the morning. He says $500 & I'll have a new working master key. Plans on reflashing existing ECU. Then I can program a second one on my own using new master key. Dealership can cut you a new key for under $50 as long as you have a working master key. I only had a Valet key.
Discussion Starter · #12 ·
Locksmith came this morning. Gave me two options. Reflash exiting ECU & make a new master key for $500. Option 2 make a new valet key for $125. Toyota dealership would not do that. Said it wasn't even an option.
Automotive locksmith was at my house for 30 mins. Fast & professional. I now have two valet keys & the key that the dealership made me that locks & unlocks the doors only. I'm happy w that. After all it's an 11 yr old vehicle. Thanks for your thoughts gents.
Quick question.... what does the valet key do exactly on our Sequoias? Is the only difference that it will not unlock the glovebox or something? Does it somehow limit the maximum speed or impact operation at all? I can't remember what the valet key does.
A valet key operates the vehicle normally but will not open the glove box. Not sure if it would open a trunk, hatch or tail gate though.
Seriously? The only drawback is that the valet key doesn't lock/unlock the glovebox? That means that I have three keys now! In the 7 years of ownership, it has never even crossed my mind one time to use that feature. What a silly limitation. Small price to pay. If I get in a pinch... I'll get another valet key cut and motor on in my 11 year old truck. Great thread and great advice!
I have the same problem, bought a 2007 Sequoia and was only given a valet key. I had no idea that this would cause such a headache. At the time I didn't know there was such a thing as a valet key vs. a master key (my last "new" vehicle was an '04 ford econoline with zero bells and whistles). Today I was told by a dealer DE that if it were only a reprogramming of the ECU it would be just under $600, plus the cost of the keys! Turns out that isn't an option (according to this dealer) they said there are a few model years of sequoias/tundras that in this situation require an ECU replacement. That would be around $400 for the ECU, $600 to program it, and then the cost of the keys on top of that! So, basically around $1200 for a set of keys... Makes your quote of $576 seem rather decent, which is of course absurd. It is my understanding that the valet key won't lock/unlock the glove box, or allow the vehicle to go into "programming mode" to set up a new key fob or the built in garage door opener buttons. Now, I could clearly be mistaken about that, as I said I didn't even know there was a difference in the keys when I first got it, but I am thinking that may be why I couldn't set my garage door opener to the car. No big deal, really, its a feature I didn't care much about anyhow. Same with the glovebox thing. A key fob would be nice, but not to the tune of $1200... So, I think I'll be calling a locksmith.
I only have a valet key... you can do everything except for:
*Lock/Unlock the glovebox
*Program your own additional keys
You CAN!
*Roll up/down the rear glass
*Program the homelink garage door opener
*Program additional keyfobs
I was quoted 500-600 by the dealer for new master keys for my '07.
1 - 20 of 30 Posts
