Looking for a replacement for a slow leaking radiator, have found some from $146 to $300+. Anyone got a source for a cheap/good replacement for a 2K V8 Tundra?
Is there really much difference between the high and lower priced ones?
You will get what you pay for as those cheap ones are made very poorly! I learned the cheap way once and will use OEM next time!
When my radtiator started leaking about 3 years ago, I took it to my local shop. The owner recommended that I try a rebuilt radiator from a local company that he said does good work. I agreed to try it (I had to give the company my old radiator as a core trade) and it has worked well for at least 3 years now. I think I paid $125 for the rebuilt rad.
thanks for the info, looks like a pretty easy swap. Is there anything more to it than the 4 bolts on the radiator, the other four on the fan shroud and the hoses?
