Replacing Head Unit and Amp need wiring diagram,color codes Tundra 2003
Hi,
Help Is Appreciated!
I am replacing the Head Unit and Amp in my 2003 Toyota Tundra because the CD player plastic ejection gear broke. Can someone tell me which wires are which? And what wiring harness adapters I would need? I don’t want to cut up the factory wiring harness if possible.
I have a 2003 Tundra Deluxe cab. I have the 6-disc changer 8620-0C090 and the 6-speaker setup, which are 2 6.5” speakers in front and rear + two tweeters in the front. The small amp was located beneath the HU 86280-0C010.
Can someone tell me what these wires are? And hopefully send a wiring diagram.
There are two connectors going to the Amp:
The 6 pin Connector:
Yellow
Black
Red
Green w/ white stripe and silver bands (5VDC when lights are on)
White? Beige?
The 10-pin connector to the Amp
Red (12VDC) Battery?
Green
Grey (12VDC) Accessory?
Brown
Pink
Purple
Blue
Light Green
I think this connector is steering wheel controls (don't have them), it doesn't seem to do anything when I unhook it.
There is a connector coming from the amp that plugs into the HU and there is this 20-pin connector coming from the same wiring harness as the amp inputs that has 3 attached wires.
20-pin connector coming from underdash wiring to HU.
Blue w/ silver bands
Red w/ silver bands
Green w/ black strip w/ silver bands
I don’t know of any wiring adapter for this connector?
I think the wiring harness for the ones that plug into the amp is TWH-950 from American International?
Hi,
Yellow
Black
Red
White? Beige?
Green
Brown
Pink
Purple
Blue
Light Green
Red w/ silver bands
