anyone have fog lights mounted in the rear to use as a reverse light? i have a 07 Tundra and looking for some suggestion on what fog lights to put in the rear. the stock reverse light is not enought light for me at times when i reverse.
That looks like a nice, bright, and quick option. I thought about ordering one but not for $90. It would be ok if the case was metal but it is just plastic so it seems likely to break when left mounted on the trailer hitch for any length of time. The only plus is the easy no-mod installation.White Night Rear Lighting System, Truck SUV Reverse Lights
I have this on my '05 DC and '07 FJ (rolling blind spot) It lights up the world behind you.
Rich
may have to modify the wire connector to make it fit. i was thinking about getting some piaa fog light buts its like $150 on ebay.White Night Rear Lighting System, Truck SUV Reverse Lights
Rich
I have had no issues with breakage, its a very sturdy housing, Some 'plastics' are stronger than steel you know.That looks like a nice, bright, and quick option. I thought about ordering one but not for $90. It would be ok if the case was metal but it is just plastic so it seems likely to break when left mounted on the trailer hitch for any length of time. The only plus is the easy no-mod installation.
I will stick with my foglights from Walmart. For $15 you can get just as much light and mount the lights up under the back of the bed or the corners of the bumper for better protection. You can also purchase more powerful foglights or even a set of 4 for less than $90.
