Does anyone know which color wire is the reverse wire in the rear hatch loom? I'm installing a backup camera on the rear tailgate next to the license plate. I know the yellow/black wire behind the instrument cluster will trigger the monitor when the Sequoia is put in reverse, but need to splice in the camera in the back hatch to power it up when in reverse.
Worked on it today. '05 is red with a blue or black tracer (forget which). I took out drivers tail light and tied into reverse leads a couple inches from bulb/socket. Ground is white/black I think. Confirm with test light/meter, ignition on, in reverse with parking brake on.
That's how I found mine. Sorry no one responded. What camera are you installing? Do you have an aftermarket stereo?
Discussion Starter #4
