Revtek Vs. Daystar - How about both?
1016 Views 3 Replies 3 Participants Last post by  Ricirich071
Hello everyone, Just bought an new Tundra and want to put on a lift to level it out. I've been looking at these lifts and wondered if I could use both and maybe add another block to the rear for a total 5 or 6 inch lift. Anyone know if this is possible???
You can't use both. Stacking lifts like that is very very dangerous for yourself and for your truck.
Either level out your truck or get a real 5-6 lift kit from RCD or Tuff Country.
you can NOT stack spacer lifts. if you want 5-6 inches of lift without spending the 1k on RCD or the tuff country.....look at a 2.5 spacer kit with a 1-3" body lift. dont know if any body lifts are out for the 07's yet but i know they will be shortly. your cv axles and ball joints can not take over 3" of front lift from a spacer or coilovers...to go above that with a suspension lift you have to look at drop bracket lifts like the RCD, and Tuff country.
Ok I'll just have to be patient and wait for someone to make a true 6 inch lift. Thanks for the info!
