hello i have a 2003 sequoia limited with jbl radio. my factory radio is toasted, i just want to replace aftermarket android radio. i like to know what kind of wire harness to use. there are not much info for wire harness on jbl system.
thank you
Metra 70 8113 if I remember correctly the rca on the harness would plug into the preouts on headunit instead of having the speaker signal. I bought several of them before I got it correct. Goodluck and I'm sure someone will chime in and correct me if I'm wrong Goodluck and let us know what you find out thanks in advance.
Just did the very same thing about a week ago. Here is the link you will need. You will have to come up with a different option if you plan to run another amp for some subs (you end up using all your RCA plugs with the harness). I only planned to use the factory speakers for now.
Crutchfield has excellent customer support and harness adapters. Have one in my 2002 Sequoia but did it so long ago have no clue what number was.
I originally used the 70-8113 with a Metra TYTO-01 JBL Amp Interface until my amp and/or interface began failing. I have since bypassed the factory amp completely using the Metra 70-8117 harness.
