I have an 04 Sequoia with only 27K miles on it. I figured I would bring it into a new local Toyota dealer and get some items serviced. I asked them to lube the drive shaft, replace the plugs, replace the diff fluids, check the brakes and replace the front brakes if they needed it. I thought the front pads would need replacement by now.
The tech called me at home and said the front pads were fine with 30% left and that they would just clean and lube all the brake parts.
When I picked up the vehicle later that day, I was surprised at the total cost..... $409.65.
Clean & lube frt & rear brakes.............$136.00
Diff fluid service...............................$137.95
Lubricate drive shaft.........................$34.00
Replace spark plugs..........................$71.36
Tax...............................................$30.34
I've had the drive shaft lube before at another dealer for only $19.50.
Do you think this dealer charges too much? Any other had similar service done and paid similar prices?
Thanks,
Bob
Thanks,
Bob
